Trans Cooler Sprung a Leak..now what?
Old Dec 30, 2007 | 01:39 PM
Arcon12's Avatar
Default Trans Cooler Sprung a Leak..now what?
Hello!
I Traced a persistant oil leak tosomewhere infront of the radiator this afternoon. Appeared to be coming from the Trans cooler. I removed and cleaned it up then pressure tested it. YUP! sure enough it had rusted through in a particular spot Spraying everything behind it w/ lube[:@]. I figure there's no easy fix like JB weld, so.. Now the big question -
Do i replace with a new or usedOEM unit or try to upgrade to a newer OEM or aftermarketone. BA has new OEM for ~$500 and another (ESR1703G) for $300. Anyone had this issue or tried to upgrade to a newer unit?
Old Dec 31, 2007 | 07:13 PM
Default RE: Trans Cooler Sprung a Leak..now what?
See if you can find a local shop that makes new hydralic line and have them make you a new set.
jamf92
May 8, 2015 11:31 PM
TRIARII
Nov 5, 2014 10:29 AM
javven
Jul 15, 2012 10:09 AM
kruth
Nov 12, 2009 08:05 PM
The People Family
Aug 6, 2008 10:32 PM
