Rear Hatch Door Stuck
Old May 10, 2008 | 12:18 PM
rookie's Avatar
Default Rear Hatch Door Stuck
Good-day all,
Problem: I have an '02 Disco II with a 'stuck' rear hatch door that will not open...the handle feels the same when I pull up on it locked or unlocked. I took it to the local LR dealer who informed me that it was working, but when i tried it before leaving the dealer it did not work. (They said i could re-schedule, which is about 1 month from now). Anyhow I don't want to wait, I would like to Do-it-Myself. Can anyone direct me on how to get into the 'stuck' door so I can diagnose the exact problem?
BTW, I already took out the LR decal from the plastic casing covering the handle, but it doesn't reveal anything. I need to get into the door or get it opened.
Thanks for any help, this one's frustrating.
Old May 10, 2008 | 12:43 PM
Default RE: Rear Hatch Door Stuck
Remove the LR emblem from the cargo door, take a spray lube and spray the handle and all the moving parts that you can see.
Work the handle, repeat spray. Keep doing this until it opens.
Once the door is open spray the door latch too. Then open the door all the way and spray the slide and roller along the bottom of the door. Open and close the door a couple of times to get the lube worked into everything rearlly well.
I use bike chain lube on my door slide.
Do this once a month and after every car wash.
Old May 10, 2008 | 01:48 PM
jkid's Avatar
I found that I had give mine a few good wacks with a rubber mallet near the latch to get it to free up. Once open I took the door apart, pulled the latch mechanism and cleaned everything up. Sprayingthe actual latch mechanismwith lube as mentioned above may help enough though.
Old May 10, 2008 | 03:02 PM
rookie's Avatar
Hey folks, found the problem...the child lock has slipped into locked position and required me to use a small screwdriver from the inside of the vehicle and lift it to unlocked with the door stuck shut! It was tight but worked out and it works great now.
Old May 10, 2008 | 03:07 PM
Do what we said or you will have problems.
The child lock being on will not affect opening the door from the outside.
Alex_M
Jun 25, 2015 09:46 AM
ImQuattro
May 1, 2014 08:36 PM
TinSoldier
May 20, 2010 09:29 AM
pilsner
Jan 13, 2008 04:00 PM
tsuami1
Nov 12, 2007 12:14 PM
