Rear height sensor height adjustment help!!
Old Apr 3, 2024 | 09:32 PM
sayeedA's Avatar
Talking Rear height sensor height adjustment help!!
one of my height sensor arm broke off. I replaced with a new one now the height of that side is like 6 inches higher than other side.
I have a Autel MaxiSys MS 906BT Scanner that I use for all of my vehicles (BMW, Mazda etc) works fine. have not tried on the D2 suspension nor I know that if that has any height adjustment features.
Question, is there any ways to manually adjust the height? I would appreciate any suggestion or if anyone in Denver area could help me with your Fancy scanner. I will owe you a dinner or Happy hour or just connect with fellow traveler.
Old Apr 3, 2024 | 10:27 PM
Harvlr's Avatar
I don’t know about the D2 but my P38 needs to be done via the Nanocom (or something similar)
Old Apr 4, 2024 | 10:13 AM
sayeedA's Avatar
I don't know how one would adjust these sensors. they are Mechanical with a range that turns on and cuts off by rotating. I may be wrong. when I changed the new sensor i forgot to disconnect the battery that was mentioned on some of the posts. Truck is tilted so far up one side not drivable. I wonder if i let the air out on the pump side and disconnect and reconnect the battery, if that will help resetting. I don't have a Nanocom unfortunately. Trying to do this manually.
Old Apr 4, 2024 | 12:15 PM
Harvlr's Avatar
The Nanocom doesn’t adjust the sensor, it adjusts the desired height setting in your SLABS computer.
JMV
Dec 25, 2021 12:10 PM
Chum
Oct 6, 2021 06:35 AM
TOM R
Jun 14, 2021 12:15 AM
Curtis Hudson
Nov 29, 2017 07:38 PM
ljdiscovery
Oct 17, 2016 01:40 PM
