rear hub
Old Jun 18, 2010 | 09:32 PM
JumPeR04's Avatar
Default rear hub
which way does the wheel bearing go in and like how far they should go in the hub ...should they be press in by machine or can i do it also how does the FTC5268 rear hub seal go in...thanks guys
Old Jun 18, 2010 | 09:45 PM
Danny Lee 97 Disco's Avatar
Did you look at the RAVE? It has to seat all the way. You should be able to push it in with your fingertips. I printed several pages from a variety of sources before I did mine. If I remember correctly, there was a good write up with all the step by step and photos on DiscoWeb.org for doing the rear brakes and hub. I know the RAVE covers all of it.
Doesn't the tapered side go on the inside? It's been a while since I did mine, but all the printed material is in a 3 ring binder in the back of my Disco. I'll look at it later.
Old Jun 18, 2010 | 10:01 PM
JumPeR04's Avatar
thanks but it does not show which way wheel bearing go in or the seal
Old Jun 19, 2010 | 05:16 AM
antichrist's Avatar
If you look at it carefully, you'll see the small taper goes towards the center of the hub on both the inner and outer bearings, there would be no way to install them otherwise.
Never use new cones with old cups.
Old Jun 19, 2010 | 07:03 AM
JumPeR04's Avatar
thanks everyone after my cup of coffee i am going start on it ... i will report back in a hour
Old Jun 19, 2010 | 10:09 AM
JumPeR04's Avatar
ok i got it on but the stud is totally differnt from the one i took off... it got a cut line instead flat piece so i got get the new washers for it or did paul send me the wrong part
Old Jun 19, 2010 | 11:57 AM
lordmorpheus's Avatar
If this is Paul at Aristocrat, the part should be correct if you gave him all the correct details, including the VIN. Paul is the ONLY person I talk to there concerning my personal vehicle. For vehicles at work, I will also talk to Charles; he seems pretty good too. In the several years I have been dealing with Paul, I have only received one incorrect part (transmission pan spacer for the mounting bolts) and that is because I didn't specify whether I needed a corner or side spacer.
PS: Where in MO are you?
Old Jun 19, 2010 | 01:53 PM
JumPeR04's Avatar
monett mo ... i got hold of him and he told me if he had the washer he whould send them so i cant find a washer for this stud....
Old Jun 19, 2010 | 08:23 PM
JumPeR04's Avatar
Update..... Still couldn't find the washer so I gave up again tonight....
Old Jun 20, 2010 | 04:11 AM
antichrist's Avatar
The spacer should go on, then the inner nut, before you install the locking washer.
Also, I can't see a bit of grease on the bearings. The bearings need to be well packed (grease between all the rollers) and the space between them about 1/2 full of grease before installing the hub.
