Rear hub lubrication...
That is right...unless you like sitting on the side of the road waiting for the tow truck because you guessed wrong about that and didn't grease the bearings and they burned up and failed and seized and broke. I'm sure you get the idea. No, of course that wasn't me.
For Discos, there is a seal between the two spaces. That seal can leak, so sometimes they get mixed. I read that the way back Land Rovers (and maybe some military models) did not have a seal there, so used axle oil for the bearings. Tended to be messier when fording streams.
