Rear LH brake light goes out when brake is pressed only with lights on
Old Oct 9, 2013 | 08:07 PM
rreinholt's Avatar
Default Rear LH brake light goes out when brake is pressed only with lights on
My 2004 d2 has the rear LH brake light go out when I have the lights on and press the brake pedal. The light is lit up normally with the other running lights at night. The brake light works normal with lights off. Any ideas?
Old Oct 9, 2013 | 08:14 PM
jafir's Avatar
Wrong bulb, corrosion, or one busted filament in a dual filament bulb would be my guesses. Not sure if they all apply to this particular bulb.
Old Oct 9, 2013 | 08:42 PM
rreinholt's Avatar
I have replaced the bulb multiple times with the standard bulb. Cleaned the terminals all to no avail.
Old Oct 9, 2013 | 09:52 PM
Madlands's Avatar
I had the same issue once.
Open the rear door and remove the vent cover thing on the passenger side. There's a bolt in there from the body pointed toward the front of the vehicle. That's a grounding point and the nut can back itself off.
Just reach in there and tighten it up and you should be good. Hope it works for you.
Old Oct 10, 2013 | 08:47 AM
rreinholt's Avatar
Thanks, will look at that tonight.
hallfleming
Sep 5, 2024 07:35 PM
firefihter23
Dec 21, 2012 07:32 PM
Externet
Dec 6, 2012 10:17 AM
marlymarl
Apr 21, 2012 12:49 PM
cationmoted
Nov 9, 2010 06:54 PM
