Rear Main Seal
Rear Main Seal
I bit the bullet, bent over, and agreed to have the dealer replace the rear main seal on my 2004 D2...I don't feel too bad about it though seeing as I had a few gaskets including the head gaskets and valley pan gasket replaced under warranty and paid only $100 for those.
...replacing the rear main seal is way over my head mechanically and I would not trust myself to screw around with the transmission and other things in order to get to that particular seal to change it...is there anything else that I should ask them to check/replace while they're pulling everything apart? I had them replace my wires and plugs while they had the engine apart for my headgasket job for no added cost, except for the price of the wires and plugs, and wanted to ask the experts on here what I should squeeze into that job for free...
...and yes, I am sure that the rear main was going bad...followed the dye and saw the leak with my own eyes.
Thanks for the concern Ryan...I double/triple checked and on top of that am confident my mechanic is telling me the truth...I've known him for years and have bought a few cars from their dealership.
@ Spike...thanks, I can't off the top of my head rememeber when that was done...I'll check and have them throw that in if it wasn't recently.
@ oyster...mine has 76,500 on the clock...if yours has about the same or less you shouldn't have to worry too much...from what I understand the RMS usually doesn't go out this early...just my bad luck...job is costing me ~$1,300 give or take a few bucks.
www.gouniversalproducts.com or your local parts store.
i used some of the white shepherd OIL STOP LEAK in my rear axle, NO MORE RIGHT HUB LEAK!! I also used some in my t-case and no more gear oil seepage between transmission and t-case. It takes a couple of days and is the consistency of brake fluid but completely clear like water. I recommend it too.
