Rear O2 sensor readings
Old Feb 23, 2017 | 04:26 PM
Motorhead1's Avatar
This link explains how O2's work. I know it's a chevy link, but it's all the same.
Understanding Oxygen Sensors to Diagnose Fault Codes
Old Feb 23, 2017 | 08:47 PM
chubbs878's Avatar
I don't have any fault codes for sensors or otherwise and the voltage constantly switched @ all 4 sensors, it has always been like that but this D2 is the only vehicle that I have seriously investigated on a regular basis.
Old Feb 24, 2017 | 08:37 AM
Motorhead1's Avatar
if your post cat 02's are mimicking the pre cat 02's, your catalytic converters are toast.
Old Feb 24, 2017 | 10:13 AM
chubbs878's Avatar
damn that's crazy. how will I know when the cat' converters are faulty enough to warrant a replacement?? the truck runs good and no CEL
--never any problems with emissions testing/registration. so I'm sure they will let me know as the truck won't pass emission if the cat's aren't collecting the hazardous stuff, right?
Old Feb 25, 2017 | 09:17 AM
Motorhead1's Avatar
If no light on the dash and if the DEQ doesn't do a sniff test on your exhaust I guess your fine? Idk
Old Feb 25, 2017 | 01:10 PM
mln01's Avatar
I agree with this. Remember the post-cat sensors have nothing to do with engine management. A post-cat O2 code simply indicates to you, and to your DEQ, that you need a new cat.
I disagree that the post-cat O2s should always read a steady voltage. Perhaps when new but not in my 17-year old truck.
Several weeks ago I accidentally set up my UltraGauge to read Bank 2 Sensor 2 instead of B2S1. What I observed is that the B2S2 voltage switched back and forth around 0.45v but it did so much more slowly than the pre-cat sensor. That is what it should do, as I just now confirmed by again digging into the RAVE (page 270 of my RAVE pdf).
Post-catalytic heated oxygen sensors
  • Normal catalyst - ~ 200 to 650 mV, static or slowly changing
  • Defective catalyst - ~ 200 to 850 mV, changing up to same frequency as pre-catalytic heated oxygen sensors
Old Feb 25, 2017 | 05:07 PM
jfall's Avatar
Rear O2's put out a CONSTANT voltage when the catalytic is combusting the most waste.
Example-
UP a hill with the pedal down you might get .245 volts DC out of the rear O2's.
At idle - 0 volts.
The rear O2's exist to make sure the catalytic converter is working correctly.
See
http://jeffreyfall.com/landrover
Old Feb 26, 2017 | 04:08 AM
Luckyjayb's Avatar
I've got new cats so I know that isn't my problem. I ordered new walker sensors and after I get them installed, I'll report back. I think a lot of mine was the fact that the front one is bad and causing it to burn lean on bank 2 hence it showing a higher reading on the rear of bank 2
Old Mar 2, 2017 | 06:37 PM
Luckyjayb's Avatar
Well swapped out my wires and put kingsborne 8mm with the Kevlar boot protectors (yea snake oil I know) went for about a 30 mile test drive and now the o2 sensors seem to be working perfectly and have no codes!!!! I did order a set of walker o2 upstream sensors and still will put them on.
Old Mar 3, 2017 | 10:14 AM
matt3502's Avatar
Please keep us in the loop.
