Rear Panhard Conversion
Old Sep 5, 2013 | 09:22 PM
ZGPhoto's Avatar
Originally Posted by ScreamingLife
Love it! Thanks for the update! I will look into this once I'm done with my swap.
Definitely do it!
Old Mar 9, 2014 | 11:24 PM
dusty1's Avatar
I'm in, too....little different bracket location. trimmed a bit on frame bracket, to gain desired location and mounted axle bracket on the outside of spring.
Attached Thumbnails Rear Panhard Conversion-dsc_0812.jpg   Rear Panhard Conversion-dsc_0821.jpg   Rear Panhard Conversion-dsc_0823.jpg   Rear Panhard Conversion-dsc_0825.jpg
Old Mar 10, 2014 | 02:16 AM
dr. mordo's Avatar
I'm having trouble understanding this.
So this mod allows the rear end to travel more?
Old Mar 10, 2014 | 07:31 AM
dusty1's Avatar
=to get more articulation. but my watts started making the worn bushing clang....so I figured, going to be under there anyway, might as well try to improve.
Old Mar 10, 2014 | 08:11 AM
ZGPhoto's Avatar
Damnit Dusty, so jealous! I may have mine redone with the bracket on the outside of the spring, it definitely gives you more articulation.
Mordo, like Dusty said, yes it gives you more articulation, but the panhard kit is cheaper than the factory watts bushings anyways!
Old Mar 10, 2014 | 08:25 AM
dusty1's Avatar
I got 43" OA rod length (bolt to bolt) in there.... so that should be pretty decent.
Old Mar 10, 2014 | 11:59 AM
Dane!'s Avatar
I know it'll give you extra articulation, but does your axle want to drive horizontally when on the freeway hitting a bump? or is it so minor that its unnoticeable.
Next you guys should modify your radius arms and put some orbital bushings on the frame link, then you'll just be limited by shock travel
Old Mar 10, 2014 | 12:07 PM
ZGPhoto's Avatar
Not at all really, not any more than the front axle which uses the same setup!
I want to get orbital bushings but need to find the exact size of the bushing first!
Old Mar 10, 2014 | 12:12 PM
Dane!'s Avatar
2.63'' I believe is what most people use for their frame links on disco's, but you have to modify the mount on the frame anyway before swapping to it or the outer part of the bushing will bind.
http://www.ballisticfabrication.com/...nt_p_1636.html
Also, I would be okay with the front axle moving left to right, because I can correct that with my steering wheel, that back... not so much
Old Mar 10, 2014 | 12:14 PM
dusty1's Avatar
no running like a ferret here.
talking strictly about axle line up, not speed.
