Rear Panhard Conversion
Damnit Dusty, so jealous! I may have mine redone with the bracket on the outside of the spring, it definitely gives you more articulation.
Mordo, like Dusty said, yes it gives you more articulation, but the panhard kit is cheaper than the factory watts bushings anyways!
I know it'll give you extra articulation, but does your axle want to drive horizontally when on the freeway hitting a bump? or is it so minor that its unnoticeable.
Next you guys should modify your radius arms and put some orbital bushings on the frame link, then you'll just be limited by shock travel
2.63'' I believe is what most people use for their frame links on disco's, but you have to modify the mount on the frame anyway before swapping to it or the outer part of the bushing will bind.
http://www.ballisticfabrication.com/...nt_p_1636.html
Also, I would be okay with the front axle moving left to right, because I can correct that with my steering wheel, that back... not so much
