Rear Radius Arm Bushing Replacement - Where to put jack stands?
Old Apr 24, 2024 | 10:13 PM
Brandon318's Avatar
Default Rear Radius Arm Bushing Replacement - Where to put jack stands?
Replacing the fronts is so much easier with the axle hanging free. It's so easy to maneuver it around to refit the radius arms. With the rears, is it the same way? The frame back there goes way too high to mount jacks on the frame and thus allow the rear axle to hang freely. Where are you all placing rear jack stands for this job? Or are you just swapping them out with wheels on the ground?
Old Apr 26, 2024 | 11:33 AM
zski128's Avatar
I did mine with the wheels on the ground one side at a time. However I have a 3” lift and 33” tires so plenty of room.
Old Apr 26, 2024 | 02:54 PM
Brandon318's Avatar
I could always use ramps to achieve the same outcome I suppose. And you didn’t have issues with the axle moving under load that way?
Old Apr 26, 2024 | 07:30 PM
zski128's Avatar
I chocked the wheel on the side that I removed the arm.
disco_nap
Oct 2, 2022 07:41 PM
Fastercat
Oct 6, 2020 10:11 AM
Jeff Blake
May 8, 2017 09:50 PM
lost in france
Defender
Jul 26, 2011 07:18 PM
dammad
Apr 28, 2007 06:17 PM
