Rear skylight stuck open -help!!
Is the motor trying to work against you? Crazy thought, but try unplugging the motor then closing it. Or you could remove the motor and see if it turns in both directions. Try to put it back in the same spot.
I don't know that much about these things yet, but I have cranked open and close mine. My gasket did pop loose, maybe something is blocking yours. Removing the whole sunroof isn't that hard, if the headliner isn't in the way.
The typical mode of failure of these has to do with water intrusion in the motors due to the poor design of the sunroof pans. The motor is not sufficiently protected at the front of the pan from liquid levels and can be exposed to water. This causes the internals of the motor to rust and sieze. In terms of repair, the motors can be removed, disassembled, cleaned, lubricated, and reinstalled without removal of the headliner but it is best to remove the headliner and correct the leaks as well. To remove the motors without removing the headliners, the front o/h console has to be removed. In the rear, the screw retaining the O/H console to the roof has to be removed along with the sunroof opening trim strip. You can then move the headliner down enough to get a ratchet with a torx bit in the space and remove the motor. Suggest you review this post: https://landroverforums.com/forum/di...81/#post713877
Brandon
11-21-2011 06:24 PM
