Rear subwoofers are toast on my 2003 SE7; recommended replacement??.
Old Aug 17, 2018 | 03:54 AM
  #21
Jamie2333's Avatar
Originally Posted by JUKE179r
For $23 a pair I installed two years ago the Pyle PLG64 300W mid bass subwoofers after I blew out the stock subs.
They are good but not 'audiophile-wise' extremely great. I got what I paid for...
Well check out my link above. These I’m looking at are meant for fidelity. The website mostly specializes in home theater and hifi speakers.
Old Aug 17, 2018 | 03:56 AM
  #22
Jamie2333's Avatar
Originally Posted by bcolins
Well, turns out the Pyramids are 4 ohm. So, can't imagine the OE Phillips subs were 2 ohms which would be the only more efficient impedance. Also generally,.....amps either WORK,....or.....they DON'T. This working just a little thing is odd,.....wondering if there is something that might blow in the Sub woofer output stage,...that dramatically drops the output/volume of the subs,....if the stereo is over driven,................or.............did I toast the sub woofer amp by continuing to play the radio at volume when I had the subs out of the truck.
Anyone that can chime in on how your sub woofers work on your D2???? are they fairly loud? Do they thump pretty good when the stereo is cranked? (mine don't),...or do they seem to barely be working?? (like mine,...and some others)
Brian
Guess what I found on the reviews I didn’t even know about. Someone actually bought two for their discovery already! Positive reviews!
Old Aug 17, 2018 | 05:03 PM
  #23
Ben Matheson's Avatar
Did these fit without modifications
Old Aug 17, 2018 | 06:11 PM
  #24
Llamasayswhat's Avatar
No, you will need to cut/bang/massage the door opening to get them to fit, as well as relocate the amp as there is no mounting hole in the magnets as the factory has. They will fit in the enclosure, very tightly
Old Aug 29, 2018 | 07:42 PM
  #25
Wonder if these would work and just don't install the tweeters
https://www.crutchfield.com/p_236TERM65/MTX-Terminator65.html
Old Aug 29, 2018 | 11:49 PM
  #26
JUKE179r's Avatar
Those will work since they are slimmer in depth than the original speakers.
I don’t know what you will do with the tweeters tho...
Old Dec 1, 2018 | 07:47 AM
  #27
These might be worth a try
https://www.amazon.com/gp/aw/d/B008MAG9YG/ref=ox_sc_saved_image_1?smid=ATVPDKIKX0DER&psc=1
Old Dec 3, 2018 | 04:55 PM
  #28
garrddogg's Avatar
Default rebuilt foam surround
after.
Old Dec 4, 2018 | 12:38 AM
  #29
JUKE179r's Avatar
This wouldn’t last long with me playing some Drum
n Bass. Lol
Old Dec 14, 2018 | 06:49 AM
  #30
garrddogg's Avatar
Originally Posted by garrddogg
after.
UPDATE; Its been about a month now and they are still working great! This was a good fix. When I noticed the foam had died a few years ago I bought a used sub from a reputable used parts guy from here and the foam surrounds looked absolutely fine when I got them, during and after install. I played about 5 minutes of music after install and the foam had self destructed, I closed rear door played about a song and a half it wasn't even a loud or Basey song opened rear door and all the foam was in rear floor and no longer on subs! (I thought was in the twilight zone there and then GONE) LOL.... Moral of the story if your subs aren't blown replace the foam if its shot. It takes a little time but its not hard. No I'm not talking **** on the seller nor will I name him as they looked just fine when he pulled and sent them. (It was just one of those things I guess)
