Rear Suspenion...weird thing....DISCO 2000
Old Mar 5, 2007 | 12:54 PM
amvauto's Avatar
Default Rear Suspenion...weird thing....DISCO 2000
Here is my story, my drivers side air shock was leaking and it was sunk in the back for about 3 weeks until I changed it with a replacement....easy as hell..10 min..anyway after I changed it it went back to normal (rasied up)...I parked it in the garage for 2 days...no problems...then I parked it outside overnight, I am in Winnipeg, CAD. so it was stupid cold...I think it was -40 Celsius (-40 Farenheit) with the windchill...so when I came out in the morn it sank again...I was pissed...but as soon as I started the car, it raised and was fine....then I went to work it was again real cold and it sank it did this for 2 days, sank and raised...then it got warmer and it stopped sinking...it was like 3 weeks and no problems...then just last night the temp again hit -40 C (-40 F)and it sank...started the truck and raised...??
Right before I changed the air shock I brought it in for a Diagnostic and there were no errors with the Compressor, suspension, engine...nothing....again Rovers are not made for this type of Cold weather so I do think that the weather has an effect on this...becuase otherwise it works perfectly fine...anybody else experience this type of unexplained phenemonon????
Damn this is a long story....
Old Mar 5, 2007 | 01:38 PM
Different Drummer's Avatar
Default RE: Rear Suspenion...weird thing....DISCO 2000
My Lincoln has had air suspension (converted to coil springs) and the owner's manual says extreme cold temperatures can cause the suspension to lower. It's because the same amount of air has differing amounts of pressure at extreme temperature changes.An extreme change to cold = lower pressure in the bags.
Old Mar 5, 2007 | 02:00 PM
amvauto's Avatar
Great...that makes me feel better..I was worried that I had more problems to deal with...thanks
Old Mar 5, 2007 | 02:37 PM
Darover's Avatar
That's exactly it. As the weather goes down, the air condenses.
Old Mar 6, 2007 | 06:22 PM
amvauto's Avatar
Thanks...al is ok....well...I do love MY ROVER!!!
but I have decided to sell it...it has been a hard decision but it is time to go...
Thanks to all the Rover people...I will check in once in a while to see what;s up....
cappedup
Apr 20, 2015 09:21 PM
sean2k
Jan 27, 2010 12:32 AM
Evo_uk
Nov 10, 2008 06:06 PM
3green
Apr 10, 2008 04:46 PM
texmanmoore
Feb 11, 2008 11:40 AM
