Rear Suspension Knocking?
Old Mar 3, 2010 | 09:07 AM
LR03NJ's Avatar
Default Rear Suspension Knocking?
Not sure where the knock is coming from but sounds like its from the rear suspension when I hit some minor road bumps and puddles. I tried shaking the disco from outside but no bumps heard. Sometimes it seems like dribbling sound hitting metal to metal. I checked the muffler and pipes but no noise from there. But if its from the suspension, what part could make this hammering sound? Any guess? Thanks - Gerry
Old Mar 3, 2010 | 09:35 AM
BajaXJ92's Avatar
Do you have the rear step that sits under the bumper?
Mine rattles like crazy when i hit bumps at low speeds....
Old Mar 3, 2010 | 10:03 AM
okdiscoguy's Avatar
check your shocks. Guessing you have an 03..
helps to have the year and mileage in your sig or at least mention it so we can diagnose.
Old Mar 3, 2010 | 10:52 AM
LR03NJ's Avatar
Hi Okdiscoguy, Yes, I have an 03. Just replaced to OME last April. I have 60k miles on it. Is there something hitting something inside the shocks? Seems like it was installed properly.
Old Mar 3, 2010 | 10:54 AM
LR03NJ's Avatar
Hi BajaXJ92, I dont have that step. Anymore thoughts? Thanks
Old Mar 3, 2010 | 11:36 AM
okdiscoguy's Avatar
There are a number of bushings that could be worn on the rear of the vehicle, or it could be exhaust. My rear hanger broke on my exhaust and when I had it re-welded, it went away. Another sound, almost identical came back, but went away when I replaced the shocks.
Did you install the shocks or did you have a shop do it? Most shops will warranty their work. I would take it back for an inspection..
Old Mar 3, 2010 | 04:59 PM
LR03NJ's Avatar
Hi Guys, Thanks for the help. I found the problem while moving some stuff earlier. It was not from the suspension. All the rubbers still intact. Sound was from the rear seat hitting metal to metal. When the seat was folded up, no knocking sound was heard. So it was from the seat. I appreciate the suggestions. TY
Old Mar 4, 2010 | 06:34 PM
Urban Panzer's Avatar
Is your truck lifted, if so it "could" be your rear shocks are "topping" out, usually occurs over bumps and with a lift and on the rear of the vehicle.
Old Mar 4, 2010 | 07:22 PM
cranky's Avatar
is it your seat?
I bet it is your seat?
LOL
________
Misha
Old Mar 5, 2010 | 12:12 AM
demonlarry's Avatar
I'm with Cranky, try the seat...
With mine pushed up, I hear no knocking on mine...
