Rear View mirror -- which is the correct connector?
Old Sep 19, 2018 | 04:37 PM
RA021226's Avatar
Guest
Default Rear View mirror -- which is the correct connector?
I had my windshield replaced earlier today and, in the process, discovered that the rear-view mirror wasn't plugged into anything (I have tinted windows all the way around which is probably why I never noticed it not changing). However, once re-assembly began, I discovered that the connector on the mirror doesn't match any of the three connectors I found under the headliner (not terribly surprising considering my Disco is a Frankenstein). I know the foam-covered connector is for ACE, but which of the other two is for the mirror? I plan on replacing the factory connectors with bullet connectors when I fix the headliner in a few weeks....thanks in advance, M
Old Sep 20, 2018 | 12:36 PM
OverRover's Avatar
Have at it...…..
Old Sep 20, 2018 | 08:21 PM
RA021226's Avatar
Guest
Excellent! Thanks, M
SuzSS
Feb 10, 2026 12:55 PM
Alan Phillips
Aug 26, 2012 02:29 PM
LL2Juan
Mar 14, 2010 02:48 PM
AK Rover
Jan 9, 2009 07:59 PM
goldfishy
Jan 20, 2008 03:19 PM
