Rear view mirror removal?
Old Jun 22, 2017 | 08:20 PM
RhinoRover's Avatar
Default Rear view mirror removal?
2003 S Disco. Has anyone removed a stock rear view mirror? I can't seem to figure it out and don't want to crack the glass any further. I need to get to a small interior crack that started behind the mirror before it spreads on this newer windscreen.
Thanks!
Old Jun 22, 2017 | 08:47 PM
tcr6v1's Avatar
simply pull down and the mirror will slide off the mount. if you need to take the metal mount off (id advice against it) heat it up with a heat gun to loosen the adhesive. To re attach the bracket you'll need to find some loctite 319... nothing else works well for this
Old Jun 22, 2017 | 10:36 PM
RhinoRover's Avatar
I tried pulling both up and down. Maybe I need to try being even more inline with the curvature of the glass? There's no tabs or clips? Thanks.
Old Jun 22, 2017 | 11:43 PM
tcr6v1's Avatar
yep follow the curvature and you'll be golden. don't be afraid to get rough with her. I work at a glass shop, some of these are just stubborn
kschintz
Nov 8, 2007 03:14 PM
kschintz
Nov 6, 2007 08:17 AM
PilotDoofy
Sep 20, 2007 09:10 PM
whodey
Jul 22, 2005 12:09 AM
brickhouse
May 24, 2005 03:13 PM
