Rear Window Wiper / Washer
Old Feb 15, 2010 | 05:35 PM
4score's Avatar
7th Gear
Default Rear Window Wiper / Washer
My rear window wiper broke recently. I purchased the replacement part but am not sure how to hook up the wash feature. Do I need to take off the door panel or is just a matter of pulling the old hose out and pushing the new one in?
Thanks for any help.
Old Feb 15, 2010 | 06:05 PM
Disco C's Avatar
you need to take the panel off.
Old Feb 15, 2010 | 06:10 PM
4score's Avatar
7th Gear
Disco C, Thanks for answering so quickly
I started to pull off the panel and there is what looks to be a piece of clear plastic glued to the door. Do I need to cut the plastic to hook up the washer?
Old Feb 15, 2010 | 09:41 PM
Disco C's Avatar
mine just pulled off.
Old Feb 15, 2010 | 10:01 PM
grussell's Avatar
Jusr carefully pull the plastic off around the edges.
Old Feb 16, 2010 | 12:32 AM
EstorilM's Avatar
You all are crazy - no offense.
I just did this on Sunday and there's a hose barb attached to the nozzle where the tube attaches - just yank it off the old one and use some needle-nose pliers to put it on the new one (REMEMBER to feed it through the spring first, then attach it to the barb, then feed it back into the guides as you work your way back)
Once I saw that panel was glued on there, I decided to re-asses the tube idea hahaha.
junior496
Jan 26, 2011 05:28 PM
hilltoppersx
Sep 22, 2010 07:44 PM
krazzz
Jan 15, 2010 07:17 AM
VikingDiesel
Mar 11, 2009 07:20 PM
wildhorses
Oct 18, 2005 05:29 AM
