Rear Window wont go up
I'm sure this has been discussed here before but after doing some looking I have failed to find it. My rear window won't go up. This has happened in the past but after some time it started working again. Not this time. I remember something about a ground or something. Please direct me to the thread I need or repost the answer please.
Thank you
Joe
BTW its a 96 disco
Thank you
Joe
BTW its a 96 disco
on
Joe, will the rear window not work from either switch? There is a window ECU under the console that regulates the window operation, sometimes the circuit boards get dirty and need cleaning, some time the unit needs to be replaced.
Have you pulled the door panel and checked to make sure you are getting power to the rear window motor?
Mike
Mike
twoxred
10-04-2021 07:07 AM
