Rear Wiper Washer Hose Repair?
Old Jan 24, 2022 | 05:37 PM
specops1526's Avatar
Default Rear Wiper Washer Hose Repair?
Found out my rear washer hose has a crack/hole in it. Kept pumping it and pumping it, yet no fluid out the rear washer. Soon enough there was washer fluid pouring on the ground from the rear bumper and the area behind the floor vent was wet. Luckily the break was at the door inside the rubber wire grommet.
What's the best way to repair this? I presume I'd splice the hose at the break and use some sort of connector? If so, anyone have a recommendation for the proper connector that won't leak? The inside diameter of the hose is about 4.8mm.
Thanks
Old Jan 25, 2022 | 07:19 AM
adalton's Avatar
I cut mine and used a fluid connector to repair the hose. It works well. It will not leak with the correct connector but some high quality tape will fix any leaks.
Old Jan 25, 2022 | 08:19 AM
adalton's Avatar
Amazon Amazon
This is what I used.
Old Jan 25, 2022 | 08:45 AM
redrover75's Avatar
I just did the front ones, I wish I saw that amazon one. I paid ~$6 for each connector, wo the hoses.
Old Jan 25, 2022 | 10:52 AM
Originally Posted by adalton
Great. Thanks for the info. Did you do this for the front or rear wiper hose? I'm not sure if they are different sizes or not.
I did some searching on Amazon last night and found some brass connectors. I think 3/16 is the right size but I could be wrong. Is brass overkill?
Amazon Amazon
Amazon Amazon
Amazon Amazon
Also found some plastic ones:
Amazon Amazon
Amazon Amazon
Amazon Amazon
Old Jan 25, 2022 | 10:54 AM
adalton's Avatar
I used it for the rear. Im sure they will work for the front as well as they are the same size.
Old Jan 25, 2022 | 10:56 AM
Ok, great. I'll give it a shot. Thanks
Old Jan 25, 2022 | 11:16 AM
adalton's Avatar
Let me know if need pictures.
Old Jan 25, 2022 | 11:32 AM
Thanks, images are always good for future reference here.
I assume you just spliced the hose at the break and connected them with one of the included connectors in your kit?
Old Jan 25, 2022 | 11:39 AM
adalton's Avatar
Correct.
