Rear Wiper Washer Hose Repair?
Old Jan 25, 2022 | 11:55 AM
specops1526's Avatar
Originally Posted by adalton
Correct.
Great. Ordering the parts today. Thanks
Old Feb 4, 2022 | 01:25 AM
Bought a bunch of different connectors (brass and plastic) and the ones in the full wiper kit referenced above actually worked the best.
I spliced the line, cleaned up the ends and connected them with the straight connector. Wrapped the connection with some gorilla tape and closed everything back up. Washer works perfect again.
Old Jun 20, 2022 | 04:46 AM
eujaimi's Avatar
Default Same issue
Originally Posted by specops1526
Found out my rear washer hose has a crack/hole in it. Kept pumping it and pumping it, yet no fluid out the rear washer. Soon enough there was washer fluid pouring on the ground from the rear bumper and the area behind the floor vent was wet. Luckily the break was at the door inside the rubber wire grommet.
What's the best way to repair this? I presume I'd splice the hose at the break and use some sort of connector? If so, anyone have a recommendation for the proper connector that won't leak? The inside diameter of the hose is about 4.8mm.
Thanks
Hello,
I have the same issue, firstly it started to leak on 3rd row from seat belt (Right), then couple of weeks ago it started to leake from the driver piller, i was worried about the airbag so i took it to the dealership.
They gave me a repair cost of nearly 8000$ , they said u need to replace the hoses (500$) and all the roof head liners! + revmoving and re install the front whindshield!
SO i desided to do it myself, but i couldnt remove the piller, so any ideas?
abn632
Apr 7, 2020 09:02 AM
ZMonet
Jan 24, 2019 12:39 PM
jam583
Oct 22, 2017 05:38 PM
tdefur
Dec 15, 2013 09:59 PM
james.martin1
Oct 10, 2013 07:56 PM
