Recap of fix oil leak
Ok so overall not to too bad to tear down, but still not fun with the sun beating down on you.
took me yup 2 days from heat exhaustion on my part.
replaced the coils and wires and new plugs
pain with sai I do have to say.
now for the crappy part they put the valve cover gaskets in with RTV silicone grrrrrrr.
took a loot to just clean them up.
Now the strange stuff.
lower intake manifold a pain to get free.
Once done the valley pan gasket looked ok.
the valley gaskets well the front came apart in 3 pieces and no RTV where the heads meet the block on the front and rear.
front just fell off.
think I found the oil leak lol.
plugs where all white carbon build up except the passengers rear one by the firewall. It was a brown carbon build up.
now for the good it runs much better and idles better too and I have a little bit more pickup.
i have to see if the oil drips come to a halt now.
and need to get the coolant to bleed better.
took me longer than I was hoping but this heat killed me :-(
thanks to everyone on the advise and tips
Keith
Keith
Valley is this is my next gasket job. I just did the valve covers and oil mileage increased from 550 mi to 800 mi /qt. Valve cover gaskets absolutely dry and clean now (after running 3,500 mi).
BTW, I did the PCV mod 2 years ago and it did close to nothing to the oil consumption.
Also, I had a small leak at the rear which disappeared "mysteriously", but I attribute it to the engine oil (I have used Castrol GTX High Mileage blend oil for a year now).
Well I am glade I did all that will get it washed again underneath and see if leaking like it was.
I have been finding one leak after another.
first was front seal did that new oil pump and the gaskets there.
that slowed a lot down.
next was a leaking hose on power steering.
less oil after that
so far on this one not sure lol
after this ?
oil pressure sensor ??
the o ring between the oil filter mount and the front housing ?
or the pugs for the oil cooler lines ??
only time will tell
less oil after that
after this ?
only time will tell
Phatrowles
Jan 9, 2014 10:36 AM
