Recap of fix oil leak
Old Aug 2, 2020 | 04:14 PM
merebel's Avatar
Default Recap of fix oil leak
Ok so overall not to too bad to tear down, but still not fun with the sun beating down on you.
took me yup 2 days from heat exhaustion on my part.
replaced the coils and wires and new plugs
pain with sai I do have to say.
now for the crappy part they put the valve cover gaskets in with RTV silicone grrrrrrr.
took a loot to just clean them up.
Now the strange stuff.
lower intake manifold a pain to get free.
Once done the valley pan gasket looked ok.
the valley gaskets well the front came apart in 3 pieces and no RTV where the heads meet the block on the front and rear.
front just fell off.
think I found the oil leak lol.
plugs where all white carbon build up except the passengers rear one by the firewall. It was a brown carbon build up.
now for the good it runs much better and idles better too and I have a little bit more pickup.
i have to see if the oil drips come to a halt now.
and need to get the coolant to bleed better.
took me longer than I was hoping but this heat killed me :-(
thanks to everyone on the advise and tips
Keith
Old Aug 2, 2020 | 07:09 PM
Extinct's Avatar
Oil will not leak out of that location if you have the PCV mod done, if no mod - that area will leak.
Old Aug 3, 2020 | 01:05 PM
Discorama's Avatar
Valley is this is my next gasket job. I just did the valve covers and oil mileage increased from 550 mi to 800 mi /qt. Valve cover gaskets absolutely dry and clean now (after running 3,500 mi).
BTW, I did the PCV mod 2 years ago and it did close to nothing to the oil consumption.
Also, I had a small leak at the rear which disappeared "mysteriously", but I attribute it to the engine oil (I have used Castrol GTX High Mileage blend oil for a year now).
Old Aug 3, 2020 | 01:13 PM
merebel's Avatar
Well I am glade I did all that will get it washed again underneath and see if leaking like it was.
I have been finding one leak after another.
first was front seal did that new oil pump and the gaskets there.
that slowed a lot down.
next was a leaking hose on power steering.
less oil after that
so far on this one not sure lol
after this ?
oil pressure sensor ??
the o ring between the oil filter mount and the front housing ?
or the pugs for the oil cooler lines ??
only time will tell
Old Bertha
Jul 12, 2020 02:23 PM
CollieRover
Nov 17, 2014 09:35 AM
Pjpax
Sep 2, 2014 11:22 AM
Phatrowles
Jan 9, 2014 10:36 AM
Dino76
Jan 25, 2009 01:53 PM
