Recommended Maintenance on Disco II
Hi there!
I am a recent Land Rover owner (and loving it!). We purchased this vehicle to tow a boat/jet skiis. I have now about 72K miles on my 2001 SE. I have a mechanic who used to own a DII and he drove it and checked it out and said it is in great shape.
However, I know that slowly I will need to do some maintenance to it. I have read about u joints, transfer and diff fluids, etc. The guy who owned it before me had all maintenance done at our local dealer and it is still under warranty until 100K. Can anyone advise what things I might want to keep an eye out on for common things as we get near 80K.
I really appreciate any help you are able to provide.
Thanks again,
Garrett
Thanks again,
Garrett
So are you sure you have had the 60K service performed? I would suggest you go to the dealer that used to work on the truck and get copies of the repair orders because extended warranty companies want to see these if you ever need to have repairs made.
As for the 75K, it is more of an inspection of all areas, brakes hoses, seals, fluid levels, LOF,. Usually the big services come every 30,000 miles at the 30, 60, 90K.
Make sure to keep records of all work done and have your oil changed every 3,000 miles.
Mike
Mike
Mike,
Thanks for your message. I just went down to my Land Rover dealer today to get a print out of the service intervals. The previous owner DECLINED the 60K mile service. I have been keeping my records for my oil changes (only have done one, did it myself).
I am worried about the u joints, and the coolant hoses, and coolant, transmission, diff fluids. Do these need to be replaced soon? Also, i think it may need a brake flush and new spark plugs. Any suggestions on brake fluids and spark plugs? Also, how do go about lubing the u joints and the differential/transfer case? Any recommendations would be greatly appeciated.
Here is my list of a 60K, it is more extensive then the factory list but it will keep you truck alot healthier alot longer.
As for you questions, Send me your tele number and I will be glad to call you.
Mike
mikeljacobs@comcast .net
This is the parts list for a 60,000 mile service the way I do it.
1 Oil filter , K&N 3001
1 Air filter
1 Transmission filter kit
6 Qts of engine oil
12 Qts of ATF
7 Qts of 80/90W gear oil
2 Qts of Brake fluid
2 Qts of synthetic Power steering fluid
2 Gallons of OAT, orange coolant
1 Bottle of Lucas Power Steering additive
1 Bottle of Lucas Transmission additive
1 Can of Spray Carb Spray
1 Can Of Brake cleaner
8 Spark Plugs, I use Bosch Platium Plus 4's
1 Set of Magnacor 8mm plug wires
1 Serpentine belt if not yet replaced
2 Bottles of SeaFoam
60,000 Mile Service
Bleed the brakes
Flush and change the power steering fluid adding one bottle of additive
Service the tranny adding one bottle of additive
Flush the coolant system
Do an engine flush before changing the oil
Do an induction cleaning
Clean the throttle body
Add fuel additive to full gas tank
Change both of the diffs fluid
Change the t/case oil
Replace the plugs and wires
Replace the air filter
Lube all the drive shaft grease fitting including the 2 slip shafts
Do full inspection of brakes, hoses, bushings etc.
Hopefully I didn't leave anything out.
Mike
Mike
1 Air filter
6 Qts of engine oil
12 Qts of ATF
60,000 Mile Service
Bleed the brakes
Mike
Mike - burnin' up the boards this morning -
I would like to take my new truck through the 60K service as well.
- what internet sources do you recommend where I could get the entire parts package you mention above, for example, conveniently shipped at once?
- for my other car (an old porsche) we have the factory parts CD with all the diagrams and parts numbers - this really helps when ordering parts - is such a resource available here is Rover-land?
- once one has the parts numbers in hand - who has the best prices? for example I get all my porsche parts from a dealer on the west coast who charges by a strict formula of cost + 15% for mail-order customers - which saves lots of dollars compared to almost any other source. any businesses like that for Rover parts?
Thank you so much for your info and assistance!
Other then the Magnacor wires and the serpentine belt, all this can be picked up at your local Auto Zone.
The wires and belt can be ordered at 650-365-4145 thru Tony at Cerronies.
Let me know if you want to be walked thru some of thisw stuf.
Mike
Mike
rover2003
Dec 8, 2007 08:40 AM
