Recommended mechanic in Denver
Old Jul 9, 2012 | 07:47 AM
Banzai Jimmy's Avatar
Originally Posted by Disco Mike
as a service manager, not writer
Oops, my apologies - I'll correct above. Did you start out as a writer?
Old Jul 9, 2012 | 09:03 AM
No problem, and yes I started writing back in the early 70's for Chevy in Arizona.
Old Jul 10, 2012 | 05:42 PM
cdd543's Avatar
5th Gear
Thanks for the responses everyone. Any feedback on Peak Eurosport in Wheat Ridge? They are pretty close to me. Still searching for an 04.
Old Jul 11, 2012 | 12:50 PM
jfall's Avatar
Mike is legendary... :-)
Well, I would test drive that Rover in the Denver area.
Run it up and down hills.
Make sure it does not heat up.
Make sure it shifts well.
Make sure you can run it up to 80MPH without vibrations.
Take off the coolant cap.
Make sure it does not SPEW out coolant continuously - Your goal here is to assure head gasket is good.
Check the hi/low range selector works.
Check all mirrors.
All windows.
Check all door locks come up and down.
Get under the rover.
check the drive shafts. They need grease nipples on them. If not then bid a lower price.
Check the tires.
If Michelin then the owner probably took care of all other things.
If Goodyear - maybe other things were overlooked (cheap P.O.).
Check steering.
Listen for wheel bearings.
Check parking brake.
Make sure NO warning lights are on.
Get a scanner and try to pull codes which are not displayed yet (Pending codes).
Make sure the air injection system is working on cold start (if fitted).
This makes a LOUD vacuum cleaner noise.
Make sure the sun roofs go up and down, open and close.
Check the seats - back and forth and the angles.
Check the radio.
Look at the oil.
Check power steering levels.
Check coolant level.
Make sure the big fan moves stiff when trying to spin it.
Make sure the alternator is not grinding.
ditto for the water pump.
That's about it.
REVS
Mar 28, 2014 05:07 AM
Patrick Duffy
Jan 15, 2014 09:39 AM
Brooks
Feb 11, 2011 06:09 PM
Qputter
Jan 20, 2009 08:20 PM
KUpolo
Feb 7, 2006 11:33 PM
