Red Light After new P/S pump install [PIC]
Old Jul 4, 2010 | 10:17 PM
casanova00's Avatar
Default Red Light After new P/S pump install [PIC]
Ok so I changed out the old p/s pump for a new one, the old one broke. Anyway this red light come up and wired noise comes from the ACE Pump. I dont know what went wrong!
Attached Thumbnails Red Light After new P/S pump install [PIC]-img00093.jpg
Old Jul 5, 2010 | 12:47 AM
Willie00d2's Avatar
Did you drain the ACE resivoir? Check your belt routing. Maybe the ACE pump is spining backwards. Mine does not have ACE so I can't be much help.
Willie
Old Jul 5, 2010 | 08:18 AM
You might have air in the system and it needs to be bled.
Make sure the ACE fluid is full too.
Old Jul 5, 2010 | 09:32 AM
Waiting for your reply!
Old Jul 5, 2010 | 10:06 AM
casanova00's Avatar
Belt is on right, ace fluid is full. I will bleed the system tomorrow since today I work a 24hr shift.
Old Jul 5, 2010 | 10:47 AM
Is the ACE fluid swirling in the container when running?
Have you ever bled the ACE and P/S fluids before, if not send me your number and I call and walk you thru it.
Old Jul 5, 2010 | 03:52 PM
casanova00's Avatar
No, the fluid is not swirling in the container. No sir, ive never bled a ace/power steering before.
Squid4life
Nov 13, 2014 12:00 PM
bosshogt
May 11, 2012 10:26 AM
Christina Jon Harrington
Jan 27, 2012 12:23 AM
juan59324
Aug 29, 2011 10:05 AM
