releaving fuel line pressure
Old Apr 12, 2008 | 10:23 AM
cplthomas's Avatar
Default releaving fuel line pressure
What is the quickest way to releave the pressure. I am replaceing the filter. The haynes manual I have is for the right modle and year - but it doesnt include the 4.0. 96 D1.
Thanks.
Old Apr 12, 2008 | 11:07 AM
Default RE: releaving fuel line pressure
You dont need to release the fuel pressure to replace the filter.
But the best way to do it is to start the trk and then pull the fuse to the fuel pump, after it stalls turn off the key and replace the fuse.
Old Apr 12, 2008 | 01:04 PM
cplthomas's Avatar
Ok, thanks.
Old Apr 12, 2008 | 02:55 PM
The threads to the filter rust and it can be a bear to remove. Lube them up a couple of days before and then replace it once a year to keep things easy.
I replace mine every spring, the filter is cheap enough its worth not having the hassle of rusted threads.
Old Apr 12, 2008 | 05:09 PM
cplthomas's Avatar
I sprayed them and the exhaust (replacing cats) with PB Blaster today.
Old Jun 4, 2015 | 09:09 PM
MPDano's Avatar
Perfect! This is what I needed to know as I am going to do the Intake mani gaskets and O-rings this weekend. Is there a fuel filter on the 2000 DII's? I was told there is only the screen on the in-tank.
Old Jun 5, 2015 | 05:24 AM
drowssap's Avatar
just in the tank
Old Jun 5, 2015 | 07:42 PM
antichrist's Avatar
A mod should move this thread to the D1 section.
zeropegleg
Jul 24, 2013 10:25 PM
JerrodSteph
Jun 12, 2011 06:04 PM
leadfoot
Sep 13, 2009 09:51 AM
discoken
Nov 4, 2008 12:39 AM
ajh
Oct 28, 2007 02:24 PM
