Relocated coil packs (with pics!)
My initial reason for ditching the pump was to make room for the washer fluid bottle, and I think when I get around to building a bumper that will still be the case. I was just eager to get the job done and found this to be a very easy place to mount and didn't have to make any kind of bracketry (other than a small piece of aluminum scrap) to mount it. When I do what you've done there I will probably put the coils either right over the cruise control unit or on the open space on thr drivers side accessory bracket where the ace pump would be.
Luckily I made my harness extensions pretty long so they will reach anywhere near the motor or firewall.
The bracket for the SAI valve, mounted on the valve cover, would probably support your coil pack...it's a pretty stout bracket. I'm removing the rest of my SAI manifold tubes and garbage and might investigate moving my coil packs to this option. The cruise bracket is a good option, too, and would keep it away from engine temps better.
Only problem with a aftermarket washer bottle will be...finding one that has duel motors. Personally, I like the larger container...since you usually buy washer fluid by the gallon.
Brian.
Brian.
Brian.
Brian.
Plus, mounting the coil packs on each side...would allow you to shorten up the plug wires. The plug wire is the weakest link in the ignition system, and as they age...they allow for most resistance...which in turn, over time, can ruin the coil packs. This is why, over the past few years, you see no ignition wires at all (or as short as possible)...coil pack for each cylinder, directly on top of the plug.
Brian.
Brian.
So true!!!
Thanks! They are actually just the universal msd wire kit you can get an any auto parts store. I had to cut them to length, put the boots on, and I had to take the coil side connectors off the factory wires and crimp them onto the new wires because the coils require that wonky male fitting rather than the standard female type. I think they are 8mm.
BTW. Factory wires were around 5000 ohms, the longest of my custom wires is just over 2000 ohms.
Did you have to lengthen the wires that go TO the coil pack?
