Relocated coil packs (with pics!)
Old Jan 13, 2017 | 11:21 PM
  #21
mln01's Avatar
How did you have good enough access to do that? Wait, you were doing headgaskets, right? I guess that gave you some more room to work. Still seems tedious.
Old Jan 13, 2017 | 11:30 PM
  #22
KingKoopa's Avatar
There was lots of room with the top end off. No problem, took about 20 minutes to cut, solder, and heat shrink. I always use heat shrink on Individual wires and then use a heat shrink sleeve over the connections that has an apoxy inside that melts and then seals the whole think up when it's cool
Old Jan 15, 2017 | 08:40 PM
  #23
shanechevelle's Avatar
I change my wires with the coil pack where it is from factory.
Never even thought about moving it.
Old Jan 15, 2017 | 08:50 PM
  #24
KingKoopa's Avatar
I doubt I would have bothered with it if I hadn't had the heads off, but I'm def glad I did. My plan for the vehicle is reliability and ease of maintenence on the road and on the trail. As time goes on I would like to simplify/delete/modify any piece of convoluted British engineering that is unreliable or unfixable on the trail. It's a tall order but I think it's possible.
trialrun
Nov 11, 2014 08:41 AM
thehun
Mar 7, 2013 01:35 AM
ATXDisco
Jan 18, 2011 12:35 AM
meltdowndave
Dec 29, 2009 01:54 PM
03discoman
Apr 27, 2009 09:54 AM
