Remote keylock does not work
Old Dec 6, 2014 | 08:04 AM
Kordian's Avatar
4wd High
Default Remote keylock does not work
Hello everybody,
As mentioned in the subject, the remote key in my Discovery stopped working. No warnings, normal key does work. I suspect cabling problem. As far as I know the remote control unit is under the roof. My question is where does the wiring go to?
Thanks in advance for any help!
Regards
Kordian
Old Dec 6, 2014 | 08:54 AM
lordmorpheus's Avatar
I assume you have checked the battery in the fob... That said, are both the lock and unlock buttons not working? It is somewhat common for the unlock microswitch solder points to break on the fob's circuit board.
Old Dec 6, 2014 | 12:30 PM
Kordian's Avatar
4wd High
I assume by "fob" you mean the remote device in the key.
Yes, they are both ok, with new batteries and even tested to send signals. I read here that sometimed the BSU (if I am not mistaken) looses somehow the settings after unplugging the battery. How can I reset it then?
Regards
Kordian
caneraiser
Dec 30, 2021 09:39 PM
jeenanino33
LR2
May 15, 2013 08:05 AM
jhill15
Dec 2, 2012 03:58 PM
landRoverNewbie
Oct 13, 2009 12:26 PM
Camdisco24
Aug 2, 2009 02:52 PM
