Remove/disable SAI?
Remove/disable SAI?
So, I have seen people touch on this question all over the web, but I can't find a definitive answer.
2004 Disco 2 SE. Newly rebuilt 4.6.
I'm at the point of my engine rebuild where I'm putting back on the SAI equipment next. (I bought the Disco torn down to the block, with slipped liner, so I didn't take off the SAI personally) Most of what I'm seeing isn't broke, but I'm not confident it'll last much longer.
Looking at SAI replacement anything prices, I cringe.
So, has anyone done a write up or a walk through on getting rid of the SAI all together? My state doesn't have inspections, and I plan to drive this thing till it blows up (again).
If you knew what size the threads were then you absolutely could. Even if you couldn't find caps, you could get those things that are like nuts, except they're around a couple inches long and they're used to connect two threaded items together, and you could weld the end of those shut. Use some loctite or something to seal them.
Fuel pump and pressure sensor? My understanding of the SAI system is that it is triggered by the temperature of the coolant as indicated by the sensor in the radiator. According to RAVE, the computer looks at the coolant temp and if it is under 50 degrees C then it kicks on the SAI. If this is the case, I would imagine if you checked the resistance across the sensor when the coolant is over 50 degrees C then placed an equivalent resistor across the connector then the system would never be triggered and the fact that the equipment isn't there wouldn't be an issue. Am I missing something?
I'm actually in the middle of dealing with an issue with the SAI on my 2004 D2. The solenoid was stuck open so the exhaust was blowing back into the pump after it shut off. I can get a new Pierburg (original equipment) for $55 locally so I'm going that route. I currently have no valve in it, I just unplugged the hoses and capped the vacuum port and it hasn't thrown any codes yet. By the way, a similar valve for a Chevy costs $18.
Yes, pressure sensor. The non-sai trucks have a pressure sensor in the pump for the evaporative loss system.
The SAI trucks use a DMTL pump instead, so there is no sensor in the pump.
http://www.roverparts.com/Parts/WTR000010G
Discovery Fuel Pump
Discovery 2 Fuel Pump With Sealing Ring | Land Rover Fuel System Parts
SAI is just one component of the LEV or ULEV emissions package that is installed on the vehicles. The temp sensor in the radiator isn't related directly to the SAI, if I recall correctly, it's just another emissions component to let the computer know if the thermostat is stuck open.
Discovery Fuel Pump
