Removing the Driving Lamps
Old Jan 20, 2009 | 12:20 PM
AnnelieseMae's Avatar
From: Traverse City, Michigan...currently in Jerome, AZ!
Default Removing the Driving Lamps
Hello all!
I have decided to remove the silly stock driving lamps. They aren't reliable and I'd like to upgrade once I get the brush guard I want (a ways down the road).
Is there anything I should be aware of when removing these? I'm trying my best to not just rip them out...haha.
Thanks so much!
Old Jan 20, 2009 | 01:52 PM
Urban Panzer's Avatar
Default RE: Removing the Driving Lamps
They are not reliable because they are still using the factory system / kit
You have 2 options,
Easiest is to simply re-wire thelights straight to the full beam circuit and they will ALWAYS work. WIll take about 20 mins for anyone who can uses cutters , wire strippers,crimps and a crimp tool. All you will need to purchase is a standard 4 pin Automotive relay. If I lived close to you I would come and do it, its ever so easy.
All the details are here in the later half of the page
http://www.discovery2.co.uk/spots.html
Or you can re-wire them to still use the factory dash switch, but theres a lot more involved.
Old Jan 20, 2009 | 02:57 PM
Is there a way to remove them now, and once I get new driving lamps, reinstall them so I can use the dash button?
Or should I just forget about the dash button?
I want to take off the brush guard that I have currently. I'm not looking to replace it any time soon. It just doesn't do much of anything right now except hold lights that refuse to work.
Old Jan 20, 2009 | 08:18 PM
AK Rover's Avatar
If you need help with the truck let me know, I will be down your way next week. I need to get a little warmer weather.
Simplest way to remove them is unplug or cut the wires at the lights and unbolt them. If you cut the wires leave them long enough that they can be reused in the future in case you decide to sell them or reinstall them.
rambo
Oct 17, 2013 10:13 PM
gsgtsg
Feb 12, 2008 07:16 PM
TBW
Oct 10, 2007 08:24 AM
firstcube
Sep 15, 2006 03:13 AM
whoknows8722
Jan 25, 2006 05:32 PM
