Removing the fan from the water pump pulley
LOL...I had the same question 6 months ago.
A bit of advice...when you pull the fan clutch, make sure that the wrench you use is in decent condition. If you don't buy one, you can 'rent' them, but keep in mind that the rental tools you get from many auto parts stores are frequently worn out. If you have any problems getting the clutch loose, the first thing to check will be that the wrench you're using actually measures to be the size it says it is. (I had both 32mm and 36mm fan clutch wrenches and they measured out to actually be 38mm and 40mm respectively.)
