Hey guys I need quick help. I am literally under my truck typing this. I have the flange off but cannot get the seal out. Any help or pointers? Thanks!
It's pressed in. You'll need a slide hammer with the hook adapter. There was a thread about how to remove the seal on here not to long ago. Run a quick search to see how it was removed.
I tried to search, but was looking for quick resolution. I finally pried it out, got the new flange on and new shaft. Taking a break before I refill the t-case and see if my leaks and vibrations are gone.
Did not replace the bearing, just the seal and flange.
The AB kit is what I used. Comes with seal, flange, lock nut, felt washer and metal washer. The bearing looked okay but I wish I had ordered on while I was in there.
