Removing front output seal
Old Mar 10, 2013 | 06:25 PM
taylor15's Avatar
Default Removing front output seal
Hey guys I need quick help. I am literally under my truck typing this. I have the flange off but cannot get the seal out. Any help or pointers? Thanks!
Old Mar 10, 2013 | 06:48 PM
coors's Avatar
It's pressed in. You'll need a slide hammer with the hook adapter. There was a thread about how to remove the seal on here not to long ago. Run a quick search to see how it was removed.
Old Mar 10, 2013 | 07:45 PM
taylor15's Avatar
I tried to search, but was looking for quick resolution. I finally pried it out, got the new flange on and new shaft. Taking a break before I refill the t-case and see if my leaks and vibrations are gone.
Old Mar 10, 2013 | 08:13 PM
coors's Avatar
Did you replace the bearing and seal? Or just the seal?
I see AB sells the flange kit with the seal. Does the flange kit include the bearing as one unit?
Old Mar 10, 2013 | 09:46 PM
taylor15's Avatar
Did not replace the bearing, just the seal and flange.
The AB kit is what I used. Comes with seal, flange, lock nut, felt washer and metal washer. The bearing looked okay but I wish I had ordered on while I was in there.
taylor15
Sep 29, 2014 08:32 PM
rfitterer
Jun 3, 2014 11:29 AM
taylor15
May 5, 2014 09:27 PM
wheelgarage
Feb 21, 2012 11:39 PM
Scott R
Nov 22, 2009 01:22 PM
