Removing the harmonic pulley question
Received 1,188 Likes
on
![](https://cimg6.ibsrv.net/gimg/landroverforums.com-vbulletin/2000x1124/20190112_065713_47a5ff497ebd470b6583fbb95d5323f6eab407cc.jpg)
This is by far the safest and easiest method for locking cranks position, while oil pan is on. It locks crank in place securely and safely, no chance of something breaking and causing serious injury. You remove rubber plug below starter, rotate crank until opening appears in flywheel, insert 19mm socket on 6" extention into hole and opening of flywheel, rotate slightly until it binds up...then remove crank bolt.
Plus, you don't have to remove anything off the front of the engine to gain access, everything is done from underneath.
mollusc (09-14-2021)
Chrisinhouston
09-02-2015 03:34 PM
