removing headliner out cargo door?
Stupid question. I have a 2000 disco II I had to remove the headliner because of a sunroof leak and just had my headliner redone. when I removed the headliner out the cargo door I had trouble removing it without it bending. Is there a trick to getting it back in? I would hate to miss up the new headliner by having to bend it to get it through the cargo door. also what do you prefer to reseal the sunroof to the roof ? i'm thinking of using 3M 4000 marine sealant?
Easier with help. I had to epoxy some little metal mending straps to the underside of the weak area outside the sunroof (1 man show) then the flimsy was gone.
No need to adhere it. The pillars, compartments, visors are plenty to hold it. I layered some radiant barrier to the bare roof before re install, for a little extra insulation.
Do what everyone said above AND also unhook the rear cargo door check bracket on bottom. This will allow door to swing open further.Remove the spare tire too. However you do need someone to prevent the door from opening too far and damaging rear light an d sheet metal. You will be able to reinstall without bending headliner at all. Good luck!
jigray3
07-30-2019 07:52 PM
Taken19
10-07-2013 05:14 PM
Taken19
09-16-2013 06:19 AM
