Removing the interior A pillar trim
Old Apr 26, 2012 | 03:18 PM
Eaglerover22's Avatar
Default Removing the interior A pillar trim
I need to remove the interior driver side A pillar trim piece so I can run my ultragauge wire up to where the moon roof controls are (I don't have a moon roof). There is no mention of how to remove the interior panels in the RAVE, only the exterior. I assume it is just clipped in, but I don't want to go pulling *****-nilly and break the damn thing. Its the piece with the tweeter in it. Any help would be appreciated, as in where the clips are located, the number of clips, and how to undo the clips. Thanks.
Old Apr 26, 2012 | 03:51 PM
RedAustinIX's Avatar
Just pull it off. I've found it's easier if you work it out from the bottom. If you're really having a tough time with it, you might want to try removing the rubber gasket seal from the doorway to give you a bit more room to work with.
RedAustinIX (Ed)
cybercop
Nov 29, 2020 01:07 PM
Twins Disco
Dec 16, 2013 01:50 PM
ralphobell
Apr 1, 2013 11:09 AM
BSundownerC23
Feb 28, 2010 11:24 PM
alamosweets
Sep 28, 2007 09:42 AM
