Removing the rear wheel bearing
Old Jan 22, 2017 | 04:22 PM
  #41
Friday Night Disco's Avatar
Pictures of the ABS connector I am confused about
Attached Thumbnails Removing the rear wheel bearing-img_0164.jpg   Removing the rear wheel bearing-img_0165.jpg
Old Jan 22, 2017 | 05:07 PM
  #42
DailyDrivenTJ's Avatar
I am glad you got the nuts out without getting hurt. Hope you had warranty on your 1/2" breaker bar.
Anything requiring large torque, you should use larger socket driver.
White/Yellow separates from black. Small opening in the black has the protrusion that holds white connector into black connector. Push that in and pull each away. Dielectric grease these connectors when you are putting them back.
Old Jan 22, 2017 | 05:17 PM
  #43
Thanks for the tip and yes both 1/2" breakers had warranties.
Old Jan 22, 2017 | 07:57 PM
  #44
CollieRover's Avatar
I hear ya, I went through (2) 1/2" breakers yesterday.
I plan on reusing the existing 32mm nut unless I tear it up.
The only reason I didn't go with the 3/4" breaker is that I couldn't find a 3/4" 32mm socket. I am going to try to track one down at Sears today as the parts are showing up tomorrow and I want to get this buttoned up by Wednesday
i got mine on Amazon. I had to buy a 36mm at Napa, and a 1/2" adapter, too. Was not happy about that. Live and learn.
Old Jan 23, 2017 | 10:10 PM
  #45
Another Tricky Dick chapter closed, just need to fill up the rear diff. Diff oil is coming tomorrow and I will also do the front diff while I am under there.
Oh! while I had it all taken apart I replaced the rear rotors and pads as well.
StarView2000
LR2
Oct 28, 2019 01:46 PM
nickm347
Dec 6, 2016 11:08 AM
icatterm
Feb 14, 2016 07:08 AM
walkingzach
Feb 22, 2015 09:40 PM
Grlica
May 1, 2013 06:13 PM
