removing SAI tubes at engine
Old Jul 14, 2013 | 05:44 PM
robersonb's Avatar
Default removing SAI tubes at engine
Anyone know of a good trick for removing the SAI tubes without ruining the lines? I slightly kinked a line trying to remove them once before before giving up. This time it has to come off for a head gasket job. I am borrowing a friends torch tomorrow to heat up the bolts a little bit (yes I know, don't melt the copper to try and get them loose. Any other ideas, let me know.
Old Jul 14, 2013 | 09:01 PM
robersonb's Avatar
O.K. so realized tonight my friend's idea of using heat to loosen those SAI bolts may not be the best idea. Seeing as I have soaked many bolts including the SAI in PB blaster to help loosen things up prior to attacking them. After all, this car is in my garage so if I take out my car my house goes with it. Hmm, I didn't get to spring cleaning this year. Any idea people or how did you deal with yours?
Old Jul 14, 2013 | 09:30 PM
pinkytoe69's Avatar
You should be able to get a crescent wrench on the big nut for the tube and a second one on the square end of the part that goes into the engine.
Sorry, but I cant remember the sizes.
Old Jul 14, 2013 | 09:33 PM
robersonb's Avatar
Default wrenches
Thanks, I didn't try putting one on the engine side. I can find the sizes, that isn't a problem. Will give that a try tomorrow.
Old Jul 14, 2013 | 10:36 PM
pinkytoe69's Avatar
Sorry, meant combo wrench, but a crescent wrench might work too.
Old Jul 14, 2013 | 10:54 PM
robersonb's Avatar
Default sai
Yeah, I was going to try a combo. I never have much luck with crescents, they always end up rounding things. I just never looked closely at the other side of the nut. I assumed it was round. This should work, well better work as I don't intend to be putting 230 a side in for new ones.
Old Jul 14, 2013 | 11:16 PM
pinkytoe69's Avatar
I think the bungs were like a 7/8" or so
Old Jul 15, 2013 | 07:39 AM
NickAdams's Avatar
If you have time and patience, I like the combination of PB Blaster and heat. My O2 sensors came out with just the socket and no ratchet handle after a week of PB 15 minutes after engine shut down. As the component cools, it sucks in the penetrating oil. Just like a plumber sweats a copper pipe fitting.
roverbob
Sep 2, 2012 08:34 PM
uh60driver
Apr 2, 2012 11:22 PM
willrok13
May 11, 2011 04:09 PM
landover
Mar 15, 2011 07:53 PM
jhewitt1111
Dec 1, 2010 05:33 PM
