Removing the shift handle knob and bezel?
Old Nov 16, 2007 | 09:32 AM
Chrisinhouston's Avatar
Default Removing the shift handle **** and bezel?
Hi folks,
I need to remove my shift **** to replace the bezel and center console, the former owner had kids who used it as a step into the back seat and it is cracked.
How does one remove the shift ****. I read on a Range Rover forum that you use a small screwdriver to pry out the square button in the **** and then remove some clips. Any idea if this works in a 2003 Disco?
Thanks
Old Nov 16, 2007 | 09:59 AM
okdiscoguy's Avatar
Default RE: Removing the shift handle **** and bezel?
Pop the top off of the shifter and you will see a retaining clip inside for the button. Pop that off and pull the handle up. I am pretty sure your H/L shifter **** just screws off...
aye29
Jul 28, 2013 11:55 AM
cosmiccharlie
Mar 13, 2013 07:57 AM
Rover_Hokie
Sep 12, 2012 09:50 AM
charles21
Dec 2, 2010 08:17 AM
APSIS USA
Apr 30, 2008 10:52 AM
