Removing the Wood Trim
I have searched the forum and found no clear answers, but how bad would it be to remove the wood trim from my interior? The clear "lacquer" looking stuff over the wood has cracked and some is missing. Can the adhesive left behind be easily removed, or am I looking at replacing trim pieces with new plastic pieces sans wood?
Some of the wood may have come from the factory, in which case you might have to replace the trim with non wood trim. For example the piece above the glove box... on an S it's plastic. On an SE or HSE it might be wood. On some trims, the wood was added glued on, on some pieces there were some holes drilled to attach it.
Land Rover Discovery Genuine OEM Factory Wood Trim
