replace air springs or convert to coil - 2001 disco
Old 03-05-2009 | 11:00 AM
DJDogbone's Avatar
Well, Mike called and asked me to do a few things... I could not get the Disco to drop until I opened the rear door and sat on the bumper.
Then, on Sunday...with the Disco empty, I woke to find it dropped to the ground again!
I think I'll need to take it into Brett (mechanic) to have him take a look and clear some codes. I think the right side was all the way down and the drivers side just part of the way.
Old 03-05-2009 | 12:28 PM
Make sure he can access your SLS codes, if not find someone that can. Have them read, write them down and ask them to reset/recalibrake the system and see if the issue goes away.
Let me know what you find.
Old 05-25-2009 | 09:57 PM
DJDogbone's Avatar
SO after much deliberation, I DISCOvered that my DiscoII has some leaky airbags. I ordered the Arnott bags as the dealer wanted my first born of a set... and I put them in. It's been a couple of day and she's holding steady. I've worked on cars from the 50's through the 80's but this was my first Landy repair (currently my "project car" is a '58 VW ragtop). Changing the left one was a chore as I was not 100% on what to do so I took my time plus I was working a lone most of the time. I has my friends appear just as I was installing the new bag/spring.
The right side took 15 minutes! I'm still dealing with the 3 Amigos but I'm notr ready to dump a pretty penny on the ABS module yet. Anyone know if ther's gonna ever be a class action on the '04s to force a recall or is it a dead issue?
-dago/djdogbone
Old 05-25-2009 | 10:12 PM
skyguy's Avatar
I went through all of the same issues with my 99 disco. There are a few things you can do to ABS with out replacing mod, check post to see.
Old 07-28-2009 | 06:34 PM
DJDogbone's Avatar
OK the airbags went in...Drove great! For 2 months. Started sagging again. Took it in, cleared the codes. No good. After a week of water squirting...it was determined that the compressor was leaking now. I decided that rather than dropping $900 on a compressor, I'd drop $589 on a spring/coil conversion. Been happy but kinda sad. If I come into some real money, I'll convert it back.
Anyone want to buy some lifetime Arnott airbags?
Old 07-28-2009 | 08:15 PM
vandev's Avatar
Originally Posted by DJDogbone
I've had my Disco for about a year. I DJ at a night club and I load up my CD crates and my cd players and drive over. It DIDN'T used to do this...but in the last two weeks, when I load up and go inside, I come back out and the rear end has sagged. The first time it was just the driver's side.
This past week, I loaded up at the club, went inside and when I came out, the rear end had sagged again.
Do you think it could be something else? It appears to be happening on only one side though it was 3AM when I left the club and I think it might have been both sides.
I should mention mention that I have an HSE7 no ACE.
What do you think Mike?
Its the airbag... Mike helped me with this issue on my daughters 2000 disco II. I got a used one from my indi guy...well it looked almost new......Miami Rovers has great prices and always has parts...and i changed it myself in about an hour . It's a little bit of a pain jacking the chassie and also the suspension, but not to big a deal. $60.00 and she was back on the road. It's been 2 weeks and not a leak.
Thanks Mike...
b_woodroaster
11-05-2010 08:54 AM
tuck
10-20-2010 05:33 AM
lsmit605
09-13-2010 02:21 PM
99p38autobiograpny
03-06-2009 06:49 PM
roverrick
02-04-2008 07:36 PM
Quick Reply: replace air springs or convert to coil - 2001 disco
