vacuum Reservoir
Old Jul 28, 2009 | 07:56 AM
dgilaon4's Avatar
Default vacuum Reservoir
2003 disco 11 engine running rough-check light blinking-found that the vacuum port SAI line was completly off the Vacuum Reseroir-could that make the engine run rough
Thanks
Old Jul 28, 2009 | 08:16 AM
May be, what were the exact fault codes and how many miles on the truck?
Old Jul 28, 2009 | 08:37 AM
dgilaon4's Avatar
Default codes
org code p0441- only one left after the plugs and wires were replaced-running good up until a start up in the am. ran rough- noticed line off vacuum reservoir. 60,000 will attempt to get a vacuum line(hose) today and install ??
Old Jul 28, 2009 | 09:07 AM
441 is an incorrect purge flow with the evap system and should not cause any issues with regards to how your engine runs.
Old Jul 28, 2009 | 09:36 AM
jycsalas's Avatar
I had my SAI pump vacuum reservoir line disconnected and it threw these codes:
P1412 SAI system fault (LH side) - air delivery not reaching catalysts
P1415 SAI system fault (RH side) - air delivery not reaching catalysts
But i had no issue with engine performance.
Old Jul 28, 2009 | 09:38 AM
dgilaon4's Avatar
Default vacuum
Thanks Mike: I will replace the vacuum line and go get the codes read again. I did not want to drive it to advance with the light blinking.
will it store the error codes if in fact it was the vacuum line
Thanks again
I should buy a obd11 ?? any inexpenseive ones out there?
Old Jul 28, 2009 | 10:54 AM
JBEGIN's Avatar
http://www.roverparts.com/Parts/D3030.cfm
doesnt tell you what the codes mean, you get a bok with it that explains the codes
you can also link it to your puter and it can update itself and also link you to a site that explains what you gotta do to fix the problem, i own that same scanner but i dont use the site, i use this forum
Old Jul 28, 2009 | 02:00 PM
dgilaon4's Avatar
Could anybody tell me the size dia. of the vacuum line-heading to parts store.
attached to the vacuum reservoir
Old Jul 28, 2009 | 08:59 PM
roverguy7's Avatar
its a small hose... but its not your problem, that small of a vac leak your engine can compinsate for enough to not have a misfire... double check your wires. also with the 441 code, make sure the purge valve is connected up right
rgemmett
Nov 30, 2013 06:36 PM
dgilaon4
Jul 17, 2009 12:52 PM
Barry Childs
Nov 20, 2007 11:26 AM
ferrelltodd
Dec 7, 2005 01:49 AM
