Replace Door Post Pillars on my Discovery
Old Jun 8, 2010 | 09:29 PM
richard.ince's Avatar
5th Gear
Default Replace Door Post Pillars on my Discovery
Hello all. I am looking for some help/instructions on how to replace the left and right door post pillars on a '99 Discovery Series II.
Any help would be greatly appreciated.
Cheers,
Rich
Old Jun 8, 2010 | 10:12 PM
lordmorpheus's Avatar
Are you talking about the black plastic trim pieces on either side of the windshield, or interior trim pieces, or...?
Old Jun 8, 2010 | 10:33 PM
5th Gear
Black plastic pieces just behind the passenger and driver side rear doors. They actually sit behind the triangular glass.
Old Jun 8, 2010 | 10:40 PM
5th Gear
Uploaded with ImageShack.us
Old Jun 8, 2010 | 11:18 PM
Hopefully someone here as replaced these and can give some pointers. All I could find in the RAVE manual was "Remove RH or LH sill finisher." under B/C post assembly R&R.
Good luck, and hopefully someone else will be of assistance!
Old Jun 8, 2010 | 11:31 PM
5th Gear
Thanks. The originals broke off over time and I just ordered new ones. The issue is that I can't figure out how to tighten the bolts (located inside the plate). I think I need a special tool but just wanted to confirm.
Old Jun 9, 2010 | 06:43 PM
5th Gear
Well, I figured it out. For anyone interested you have to remove the inside quarter panels. They are the ones directly opposite the bolts you are trying to screw in. You don't need to remove them all the way just enough to access to bolt holes. What you will see then are three round pieces of tape covering up the holes. Remove the tape and you will be able to use a ratchet to remove the bolts and secure the new ones.
Old Jun 9, 2010 | 08:30 PM
If nobody had spoken up today, that was going to be one of my suggestions...
Glad to hear the idea I was going to give worked!
Paul Grant
Feb 24, 2014 01:50 PM
elboy0712
Dec 19, 2010 02:48 PM
