changing radiator in a 2002 Discovery
Old Jun 9, 2010 | 12:24 PM
RobP's Avatar
Default changing radiator in a 2002 Discovery
Can anyone give me step by step instructions on changing the radiator in my 2002 Land Rover Discovery? Thanks in advance, Rob
Old Jun 9, 2010 | 12:39 PM
Bundu's Avatar
Banned
Download the RAVE Manual, it's going to be your friend http://www.landroverresource.com/
Old Jun 10, 2010 | 05:55 AM
d2luvr's Avatar
X2 get the RAVE! It will help you more than you can imagine. I even use it for my owners manual.
Old Jun 10, 2010 | 07:40 AM
Make sure to replace the t/stat if over 75,000 miles on the truck, use only Dexcool and throw in a bottle of either Water Wetter or Purple Ice to improve your cooling system.
Do you know how to bleed the cooling system when adding coolant?
Old Jun 10, 2010 | 08:52 AM
pilsner's Avatar
make sure to bleed the system of air correctly - it is harder than it sounds. Their is a sticky under the DISCOVERY heading on here, maybe the 2nd or 3rd post from the top. It has pretty good directions.
Old Jun 10, 2010 | 10:06 AM
DiscoWest's Avatar
You'll need to remove the front turn signals. And the grill. And the horns. If you have a brush gaurd youll need to remove that as well. No, seriously. Its the most overcomplicated design for radiator removal you'll likely find. You'll need the rave. And some patience.
mln01
Oct 12, 2021 07:33 AM
batiscan
Jul 4, 2013 05:02 AM
chup1
Sep 4, 2012 08:48 AM
dapo
Apr 25, 2009 01:22 PM
fcfinc
Oct 24, 2006 08:50 AM
