Replace just one Rotor?
Old Mar 29, 2015 | 10:32 AM
OffroadFrance's Avatar
Originally Posted by Richard Moss
If it was the front I would say only ever replace them in pairs and don't waste money on getting them skimmed/turned. For the rear, the wear on the good one is likely to be minimal and the load on them in use is also minimal so replacing the bad one alone is probably Ok
I'd agree only I have my own lathe and wouldn't pay others to do the job. New good quality rotors are as cheap as chips. (TRW are v. good)
Old Mar 29, 2015 | 11:28 AM
94svt50's Avatar
Originally Posted by OffroadFrance
A smear of copper grease on the rotor face or the rear of the hub and locating center boss ensures they always release easily. I always use it on the lug nuts and studs also but many say don't but it's never caused me a problem in 12 years.
Alternatively use motorcycle chain wax spray as it isn't affected by to much by heat and water, I use either Castrol or Wurth a lot everywhere.
Good idea. The whole time beating it loose I was glad I was not on the side of the road somewhere trying to change a flat.
Old Mar 29, 2015 | 12:17 PM
Richard Moss's Avatar
I really meant "I wouldn't turn/skim them because it's a waste of time as well as money".
Skimming the discs thins them out and thinner discs can absorb less heat, which in turn increases the risk of brake fade or warping. If they were skimmed because they were warped in the first place then the underlying physical/metalurgical fault is still there but is now even more likely to reoccur.
Old Mar 30, 2015 | 08:24 AM
I'd agree with the first part about heat sink and potential fade but would challenge the latter part inasmuch as usually once a casting has heated sufficiently and stress relieved and been machined flat unless there is an inherent metallurgical defect it rarely warps or distorts a second time. Hence often the cast iron or steel exhaust manifolds from new distort and often tear the studs out of the alloy heads but after machining they usually remain flat whereas fitting a new replacement manifold often has the repeat distortion experienced on the previous original manifold. With mine I opted to machine the existing manifold for exactly that reason and has been, as far as I can tell, remains near perfect.
Old Mar 30, 2015 | 01:49 PM
drowssap's Avatar
Rotors were always cut that is why they list a minum thickness. But as labor rates got higher and the influx of cheap parts. It just got cheaper faster to replace them.
Old Mar 30, 2015 | 05:49 PM
When I replace brake pads I usually clock up and spin the rotors in the lathe to clean off the high spots and the lip on the outer periphery formed by the old pads. It makes bedding in the new pads far quicker.
Old Mar 30, 2015 | 06:08 PM
dgi 07's Avatar
Better man than me. New Pads. New Rotors.
I do it for the noise aspect as well. I have noticed the product range I work on, the rotors tend to groove quite easily. That with the formation of a lip and when they are blue, new pads, new rotors.
pottzie
Jun 8, 2013 08:49 AM
mtrdrms
Mar 5, 2013 11:35 AM
elboy0712
Dec 19, 2010 02:48 PM
rmally
Apr 22, 2008 12:26 AM
