Replaced Leaking Radiator
Old Apr 12, 2017 | 12:12 PM
LR03NJ's Avatar
Default Replaced Leaking Radiator
Quick job today. Just replaced radiator. Got to drill hole on frame to get to those locked up screws
Old Apr 14, 2017 | 11:03 PM
JUKE179r's Avatar
Wouldn't an offset screwdriver worked?
Old Apr 15, 2017 | 04:56 AM
The Deputy's Avatar
Originally Posted by JUKE179r
Wouldn't an offset screwdriver would have worked?
Look at his first picture, far left.
Brian.
Old Apr 15, 2017 | 03:08 PM
LR03NJ's Avatar
Thanks, yes, tried it first with that tool but was too tight and screw wont grip. But anyway, i had overheating problem now it gets warmer and changed possible suspects. But guys please take note with this problem. The plastic shroud is sticking to the fan sometimes and stopping air circulation. Once i open hood everything seems to be ok because i can see the fan turning but when i close hood it press down to the fan and stops it from turning. Very hard to diagnose. Please take note incase you get same problem.
Old Apr 15, 2017 | 04:02 PM
SensiRider's Avatar
Originally Posted by LR03NJ
Thanks, yes, tried it first with that tool but was too tight and screw wont grip. But anyway, i had overheating problem now it gets warmer and changed possible suspects. But guys please take note with this problem. The plastic shroud is sticking to the fan sometimes and stopppng air circulation. Once i open hood everything seems to be ok because i can see the fan turning but when i close hood it press down to the fan and stops it from turning. Bery hard to diagnose. Please take note incase you get same problem.
Mine seems like there is no clearance at all between that fan shroud and the fan blades. Is that something that could be removed in order to prevent the possibility of it hitting the fan and causing problems?
Old Apr 15, 2017 | 05:13 PM
LR03NJ's Avatar
its not advisable to remove that. It helps concentrate the air flow to the radiator like a wind tunnel effect. Better check the radiator rubber mounting so the radiator wont lean towards the fan. I had to pull the shroud together with top radiator frame towards the grill just a temporary fix until i have more time to replace the mount.
Old Apr 16, 2017 | 11:10 AM
Friday Night Disco's Avatar
curious - was there any visible signs on the fan? Such as marks where it hit the shroud that we should look for?
Old Apr 16, 2017 | 11:59 AM
LR03NJ's Avatar
very hard to tell because the fan turns fast at times and it scrapes both plastic blade and shroud very smooth. The only sign for me was too late when I felt the top of the shroud like paper thin. Not so visible because there is a yellow sticker covering it.
outdoor7or24
May 21, 2012 08:34 AM
0304Disco
Mar 22, 2011 10:32 AM
458steve
Dec 23, 2010 10:54 PM
LuvToDisco
Jun 25, 2010 11:34 AM
yvonne67
Oct 26, 2009 03:14 PM
