Traction Control 2003 D2
Old Apr 16, 2017 | 03:30 PM
RRHH's Avatar
5th Gear
Default Traction Control 2003 D2
Hi all, I have problem with the traction control....
It is coming on when hitting a bump pulling to the left
I have no fault codes when plugged in and the TC light comes on when it is operating..
I have replaced front hubs , that has made no difference, looked into it a bit more and have checked output from all four sensors , voltages equal and speed that same and tested braking on each whell with diagnostic equipment, all good.
I have new front springs to go on the front as she sits a bit low on one side
I have done the wire bypass on the ABS unit, and tried another abs ecu to no avail, only thing left would be abs unit ??
Any ideas or had the same problem ??
At the end of the road with this one..
newfrl
Freelander
16
Aug 27, 2020 06:55 AM
gamecockdisco
Jul 12, 2010 08:34 AM
daniep
Jan 26, 2009 01:58 PM
rodrick smith
Apr 13, 2007 06:09 PM
Sean 1313
Aug 30, 2005 10:00 PM
