Replaced Radiator now another leak
Old Apr 12, 2020 | 07:13 AM
Extinct's Avatar
Worst part of it is you have to take the oil pan off. Depending on mileage and how bad the rear main seal is I would consider doing the crucifix seals at the same time. Truck has to be jacked up and frame crossmember under oil pan removed. I also drop one side of the tie rod to ease removal. You may want to consider a new water pump and power steering pump gasket and be sure to check your idler pulley bearings while you are at it. I think Oreilly auto parts has a fan wrench you can borrow.
Old Apr 12, 2020 | 03:50 PM
merebel's Avatar
So you mean this cross member ?
orderofelim
Jan 9, 2020 06:09 PM
orderofelim
Jan 5, 2020 10:02 PM
remember5
Dec 28, 2016 03:34 PM
FlyingZebra34
Apr 9, 2013 09:55 PM
humroot
Mar 1, 2010 02:58 PM
